Number one on picture is the transmission check and fill hole. If you want to check it yourself, place a catch pan under the pan. Warm up engine and fluid should be between 90 and 135 degrees. Remove plug number one. If fluid over flows or drips a little bit, you are full. If no fluid comes out pump Dexron3 with a pump. It will get messy.
Check out the diagrams (Below)
Cheers
Images (Click to enlarge)
Sep 27, 2016 at 5:31 AM
