Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Drivetrain
Transmission
Reverse
reverse gear will not engage when hot
2004 TOYOTA COROLLA
49,746 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
EDMUND ANIEKWE
MEMBER
My reverse gear will not engage when hot. I changed the transmission oil but it persists. What can I do help!
May 25, 2018 at 5:12 PM
Experienced Mechanic
Good morning.
It sounds like you have either a failed seal or drum in the transmission. This is an internal failure.
What did the condition of the fluid look like when you changed it?
May 26, 2021 at 11:15 AM
EDMUND ANIEKWE
MEMBER
The transmission fluid was dark.
Here is how to change the transmission out. Check out the diagrams below. Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Images (Click to enlarge)
Add image or video
Ask a new question
Engine won't start
Check engine light
