While driving the transmission stopped working?
200,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
DUBEZ
It was explained to me that the truck was just driving along, then nothing, no gears no drive or reverse nothing. leading up to it doing this not slipping in or out, not low on fluid didn’t get hot was not pulling anything just went out of gear? Mark
Oct 29, 2024 at 9:44 AM
  • 55,658 POSTS
Yep, I have seen the input shaft break, or the front fluid pump go out inside the transmission, but I would run the codes to see if any come up. I would see if the reverse lights come on to check the gear range sensor.
Here is a guide to help:
It sounds like the transmission might need to be rebuilt. Please go over this guide and get back to us.
Oct 30, 2024 at 4:18 AM
