Transmission will not engage
2002 DODGE STRATUS
179,000 MILES • 3.0L • V6 • TURBO • FWD • AUTOMATIC
LEONARDE21
Will not engage. I was going down the road and it jumped out of gear as if it were a standard. Fluids are fine not burnt or discolored. Was told it could be sensors one or two.
Feb 19, 2017 at 2:35 PM
  • 55,224 POSTS
Hey LEONARD,
Use a scanner to see if there are any codes, this will tell you if a sensor is out, if not then it sounds like the transmission lost the front pressure pump which means it will need to be rebuilt.
Here is a guide for the scan.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Feb 22, 2017 at 6:18 AM
