it would not shift out of first
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MITCHPETTIGREW
Started having transmission trouble, not slippage, it would not shift out of first. I replaced the transmission filter and refilled to no avail. I have been attempting to change the the speed sensor but have been finding no continuity between where the sensor is or what it looks like. Any information you can give me would be much appreciated.
Feb 11, 2019 at 12:03 AM
Good morning,
Does your speedometer work? If it does, it is not the speed sensor.
A common issue for this problem is the governor. It is at the back of the transmission on the drivers side under a round cover. It just pulls out. There is a plastic gear on the end that wears out the teeth and it does not turn.
I would look at that first.
Refer to "Service Bulletins" section prior to performing the following procedure.
1. Raise and support vehicle
2. If necessary, remove exhaust system.
3. Remove governor cover from case using extreme care not to damage cover. If cover is damaged, it should be replaced.
4. Remove governor.
5. Reverse procedure to install and check fluid level.
May 14, 2021 at 4:23 AM
MITCHPETTIGREW
My speedometer does not work. However, It has not worked since I bought it and the transmission issue just recently occurred.
Check that governor.
MITCHPETTIGREW
It was the governor. Thanks. Unfortunately, the plastic bit broke off inside. Any suggestions?
I would drop the pan and see if the debris is in the pan.
MITCHPETTIGREW
It is still in the hole where the governor came out. I can see it, I am unsure how to get it out.
I cannot see it or touch it. Do you have a picture?
