it locks itself into second gear and will not shift
250,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
LRRCOOLEY
Shifts fine into reverse. After a couple blocks it locks itself into second gear and will not shift. Once it's shut off it will start to shift again for another couple blocks.
Jan 26, 2020 at 4:14 AM
Good afternoon,
Are there any codes stored in the system?
Is this the 3 speed or 4 speed? You can tell by the selector. If it has a D with a circle, it is a 4 speed.
May 20, 2021 at 9:01 AM
