transmission will not engage into drive or reverse?
212,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MY934X4
I'm stuck in the mud at the moment and when I engage 4-wheeldrive only back right rear engaged. took it out of 4-wheel and now my transmission won't engage into drive or reverse. what's going on?
Mar 17, 2025 at 1:00 PM
  • 55,808 POSTS
It sounds like you broke an axle on the left side of the rear differential. I would jack the rear of the trick up and try spinning the rear wheels, it should be obvious.
Here is how to change the axle out:
https://www.youtube.com/watch?v=ytqXLSjHNm0
Mar 18, 2025 at 4:09 AM
MY934X4
They both are working now I finally got 4x4 to disengage thanks for the advice now how to get unstuck!!! My 4x4 won't fully engage only when the passenger rear wheel is turning.
Mar 20, 2025 at 8:42 AM
  • 55,808 POSTS
Does this truck have Posi traction? Can you upload a short video as to the problem so I can see it? I have seen the front differential actuator get weak and cause the 4x4 to get stuck on or off. Here is the location so you can check it out. Check out the images (below).
Mar 21, 2025 at 1:58 AM
