Transmission replacement
300 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOSETOR
i need to change the transmission to my truck listed above. i want to replace it with a 5 or a 6 speed transmission which one do you think i should get?
Jan 12, 2019 at 8:55 AM
  • 55,658 POSTS
I would get the 6 speed if it will fit. here is a video that will walk you through how to change the transmission out, its a different car but the process is the same:
https://youtu.be/JpzefqEeVGE
Jan 14, 2019 at 2:28 AM
