transmission
100,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
LILOTANGMAN03
Transmission doesn't change out of first until it hits 3000 to 3500 RPM and then it seems alright.
Jan 2, 2016 at 7:37 AM
LILOTANGMAN03
I forgot to add the code. It was PO775 PCB.
Jan 2, 2016 at 7:47 AM
HMAC300
  • 48,601 POSTS
have a trans guy use his scanner to test if solenoid problem or something else internal. may be a bad clutch or valve body problem
Jan 3, 2016 at 12:04 AM
MILLFOIL
Early 2000's Exploder? Your 2nd gear is gone. The transmission is shot - sorry!
Feb 10, 2017 at 1:16 AM
HMAC300
  • 48,601 POSTS
that code means a solenoid problem either wiring issue, bad solenoid or what I had said previously
Feb 10, 2017 at 1:36 AM
MILLFOIL
Hope you're right! My friend's was doing the exact same thing, with the same code, and second gear was toast. Don't bother putting much money into these trannys, as they are considered to be junk by respectable mechanics. I'd drive it until you burn it up entirely. You won't cause any harm to the gear train, and who knows? You may get a year or two out of it.
Feb 10, 2017 at 10:30 AM
