If it is an electronic issue, it will store a code. Is the check engine light on?
I attached pictures of the procedure below for the fluid and the filter. Let us know if you have any other questions.
Images (Click to enlarge)
Jun 23, 2021 at 7:26 PM
REECE1287
MEMBER
I will look into getting the fluid and filter changed. no, there isn’t any codes showing. Just some occasional jerking and almost like low power when struggling to get up hills.
