Transmission not working properly
320,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
JNLMAGOS
While driving the van started to slow down, then came a knocking noise and the van stopped moving. I gave the van a minute before I turned the engine back on and the van was moving but I can feel that it was still going a little slow but no knocking noise. The transmission fuel was a little under the line and there's a leak from the rear seal of the transmission. I got the transmission fuel topped off and the van is running fine as usual at the moment. I'm still going to proceed with having my mechanic take a look and figure out what needs to be done but he's not able to look at the van until the end of this month. I live in this van so there is usually a lot of driving throughout the day but I'm able to limit some of the driving. Just curious if you think the van can make it till the end of the month in this state or not. Thanks in advance.
Feb 28, 2022 at 2:11 AM
  • 110,248 POSTS
That's a tough question to answer. How low was the transmission fluid? Also, have you checked to see if there are any diagnostic trouble codes? You don't need a scan tool on this vehicle. Follow this link:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Let me know if there are codes. Also, if it is running okay now, chances are a shop won't find the issue. Hopefully, there will be a code that will point us in the right direction.
Let me know if there are codes and if you have questions.
Feb 28, 2022 at 10:28 AM
