Accelerating from a stop the transmission would not shift into second gear?
255,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
BMAN1G
  • 48 POSTS
was driving great the other day i was waiting for someone to come out with the car running, then when i took off it wouldn't shift into second gear and i noticed the fluid leaked out a hose maybe.
Jun 6, 2024 at 6:30 AM
  • 110,251 POSTS
It sounds like you may be leaking transmission fluid. Since it won't shift, that is my first suspect.
Is the fluid leaking reddish in color? If it is, don't drive it until we find and repair the leak. This will cause damage to the transmission if it is too low.
The transmission cooler lines run between the transmission and the radiator. The lines are made of both metal and rubber. I attached a pic below and highlighted the rubber lines. These are the most likely to fail.
Open the hood and look down at the radiator between the engine fan and radiator to locate the cooler lines. Follow those to see if there is a leak at any point.
Let me know what you find.
See pic below.
Jun 6, 2024 at 1:23 PM
BMAN1G
  • 48 POSTS
Yeah, it looks like a hose is hanging from the from front of pan and yes, its redish color.
Jun 6, 2024 at 8:09 PM
BMAN1G
  • 48 POSTS
And it was leaking right near the pan.
Jun 6, 2024 at 8:12 PM
  • 110,251 POSTS
It sounds like transmission fluid. I attached directions below for removing and replacing the lines related. The last pic indicates the type of fluid you need to refill it.
Don't drive it until this is resolved.
Let me know if this helps.
Take care.,
joe
Jun 7, 2024 at 1:25 PM
BMAN1G
  • 48 POSTS
Thank you, I'll let you know.
Jun 7, 2024 at 1:39 PM
BMAN1G
  • 48 POSTS
On a scale how easy is this job and I know how to work on cars just never did this?
Jun 9, 2024 at 1:03 PM
  • 110,251 POSTS
The difficulty level will be based on the location of the leak. If it is a rubber line, I would rate it at a 3 or 4. If it is the steel line at the transmission, I would say a 5 because of access limitations.
Let me know. If I can help, I will.
Jun 9, 2024 at 1:58 PM
BMAN1G
  • 48 POSTS
Jun 9, 2024 at 2:04 PM
  • 110,251 POSTS
No problem whatsoever. Let me know how things work out for you or if I can help.
Jun 9, 2024 at 2:30 PM
