Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Lesabre
Drivetrain
Transmission
Symptoms
Engage
Transmission will not go into third gear or drive
2004 BUICK LESABRE
150,000 MILES • 2WD • AUTOMATIC
FRANKIJO515
MEMBER
1 POST
The car will go into first, second, and reverse, but not third or drive.
Dec 7, 2018 at 3:40 PM
Experienced Mechanic
It sounds like you have a turbine shaft speed sensor or a gear range sensor issue but we need to run the codes first. Here is a guide:
Also please check the transmission fluid level as well. Is it leaking?
Cheers, Ken
Dec 10, 2018 at 4:22 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
