Transmission goes into neutral while driving
220,000 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
JAYLOVESHEATHER14
Why does my transmission seem like it goes into neutral a few seconds after going? I can turn key off and start right back and same thing.
Feb 24, 2021 at 9:28 PM
  • 110,251 POSTS
That could be due to a few things. The first thing I recommend is checking the transmission fluid level and condition. Here are directions specific to your vehicle for checking. The attached pics below correlate with the directions.
________________________________
2007 Chevy Truck Equinox AWD V6-3.4L
Transmission Fluid Checking Procedure
Vehicle Maintenance Fluids Fluid - A/T Testing and Inspection Component Tests and General Diagnostics AF33-5 Automatic Transaxle Transmission Fluid Checking Procedure
TRANSMISSION FLUID CHECKING PROCEDURE
Description
Inspection of the transaxle fluid level, correct type of fluid, and the condition of the fluid for accurate operation of the transaxle.
Procedure
pic 1
Important: Routine inspection of the transaxle fluid is not required. Transaxle fluid inspection is only required if there is a symptom indicating a concern with the fluid.
1. Park the vehicle on a flat level surface.
2. Operate the vehicle in order for the transmission fluid temperature to reach the normal operating range.
Transaxle normal temperature: 60-70 degrees C (140-158 degrees F)
3. With the engine at idle, manual shift through all transaxle ranges and return to the PARK position. Leave the engine idling.
4. Clean any dirt or debris away from the area of the transaxle fluid level indicator.
5. Remove the transaxle fluid level indicator bolt (1) from the transaxle.
6. Remove the transaxle fluid level indicator (2).
7. Wipe away any transaxle fluid from the indicator.
8. Insert the indicator into the transaxle until fully seated.
pic 2
Important: Inspecting transaxle fluid level when not at normal temperature can give an incorrect measurement. The transaxle fluid expands when warm.
9. Remove the indicator and inspect the level and the condition of the oil on the indicator:
* Transmission fluid level at normal operating temperature (1)
* Transmission fluid level if cold (2)
10. If the fluid level is incorrect inspect for the following conditions:
* Fluid below level, inspect for a leak. Refer to Fluid Leak Diagnosis. See: Automatic Transmission/Transaxle > Component Tests and General Diagnostics > Fluid Leak Diagnosis
* Fluid above level, inspect for contamination of the fluid.
Important: The transaxle uses T-IV fluid, GM P/N 88900925 (Canadian P/N 22689186). The fluid is normally red in color. The oil may darken in color with more miles on a vehicle.
11. Inspect the condition of the fluid for the following conditions:
* Excessively dirty with particles in the fluid
- If there are no driveability concerns, replace the fluid. Refer to Transaxle Fluid Replacement.
- If driveability concerns are present disassemble and inspect for a cause.
* Burnt smell
- Inspect for the correct fluid.
- Inspect for conditions that may of cause overheating of the transmission fluid.
- If driveability concerns are present disassemble and inspect for cause.
- Inspect the transmission oil cooler system for functioning properly. Refer to Automatic Transmission Oil Cooler Flushing and Flow Test. See: Automatic Transmission/Transaxle > Component Tests and General Diagnostics > Automatic Transmission Oil Cooler Flushing and Flow Test
* Black in color
- Disassemble the transaxle and inspect for components that may have over heated.
* Milky or white tint in color from coolant or water
- Inspect for failure of the transaxle oil cooler. Refer to Engine Coolant/Water in Transmission. See: Automatic Transmission/Transaxle > Symptom Related Diagnostic Procedures > Engine Coolant/Water in Transmission
- Inspect for missing or improperly routed vent hose.
- Inspect for missing fill plug.
12. Install the fluid level indicator.
Notice: Refer to Fastener Notice in Service Precautions.
13. Install the fluid indicator bolt.
Tighten the fluid indicator bolt to 10 N.m (89 lb in).
If that is good, it is likely a pressure-related issue. Therefore, I recommend having the computer / can scanned for diagnostic trouble codes. CAN stands for controller area network. That is what ties all of the modules and computers together. Here is a video showing how that is done:
https://youtu.be/InIlnsjOVFA
Check the fluid and if needed, have the scan done. Oftentimes, a parts store will scan it for free. However, they may not have a scan tool to read all codes.
Take care and God Bless,
Feb 25, 2021 at 10:11 AM
