Vehicle will not move in any gear
180,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
AKIN1976
Will not move in any gear. Transmission not making any noise was just driving and started revving like in neutral stopped. It is like it is in neutral in every gear.
May 24, 2018 at 10:46 AM
Good afternoon.
The first thing I would do is verify the fluid level. Low level will kick it out of gear.
Beyond that, it could be a clogged filter in the pan. How long has it been since you serviced the transmission?
If that is okay, then it is internal in the transmission. Possibly a front pump failure or torque converter.
May 25, 2018 at 7:33 AM
