Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
5
Drivetrain
Transmission
Gear Selector
Light
When attempting to shift into gear the transmission jerked bad and lost third and fourth gears
2007 MAZDA 5
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
LARRY JOHNSON1
MEMBER
1 POST
The AT light came on I went to put it in gear it jerked really bad and it has no third or fourth gear and it is full on fluid.
Mar 1, 2020 at 2:49 PM
Experienced Mechanic
Okay. We most likely have a solenoid issue but we need need to check for codes to determine if we have a wiring, pressure, or solenoid itself issue.
If you cannot pull codes then most parts stores can do it free of charge. Let me know what the code is and we can go from there. Thanks
Mar 1, 2020 at 11:42 PM
Add image or video
Ask a new question
Engine won't start
Engine misfire
