It drives but it’s not shifting down unless I take my feet off the gas
138,170 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
TAKAYA KAYA JOHNSON
  • 8 POSTS
I have the car listed above coupe. it drives but it’s not shifting down unless I take my feet off the gas. Can you help me out with this?
May 16, 2019 at 12:23 AM
  • 55,758 POSTS
This sounds like you have a turbine shaft speed sensor that is out. To be sure lets run the codes by following this guide:
May 17, 2019 at 8:43 AM
TAKAYA KAYA JOHNSON
  • 8 POSTS
There’s no check engine light on except tire sensor light.
May 17, 2019 at 12:37 PM
  • 55,758 POSTS
Does the power seem down as well? because a plugged catalytic converter can cause this as well due to low vacuum. Even if the check engine light is not on it can still have a code. here are two guides. please run down them and report back.
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
May 18, 2019 at 4:01 AM
TAKAYA KAYA JOHNSON
  • 8 POSTS
I checked it but still no codes.
May 21, 2019 at 9:00 AM
  • 55,758 POSTS
Good job on the codes, this car has the CVT transmission which has problems. can you tell is it making any weird sounds also can you check the fluid level and condition? smell the fluid to see if it burnt and check the color. If you have not serviced the unit I would try that as well. here is a guide to walk you through the steps:
Please run down this guide and report back. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
May 23, 2019 at 3:50 AM
TAKAYA KAYA JOHNSON
  • 8 POSTS
It’s not making any noise but here’s a video of what it doing.
May 26, 2019 at 11:06 AM
  • 55,758 POSTS
Yep, it looks like the transmission is slipping. have you serviced the fluid? If not I would start there. Here is a guide to walk you through the steps with more information in the diagrams below:
CAUTION:
- Use only Genuine NISSAN CVT Fluid NS-2. Do not mix with other fluid.
- Using CVT fluid other than Genuine NISSAN CVT Fluid NS-2 will deteriorate in driveability and
CVT durability, and may damage the CVT, which is not covered by the warranty.
- When filling CVT fluid, take care not to scatter heat generating parts such as exhaust.
- Delete CVT fluid deterioration date with CONSULT-III after changing CVT fluid. Refer to See: Continuously Variable Transmission/Transaxle, CVT > Scan Tool Testing and Procedures > CONSULT-III Function (Transmission).
4. Check fluid level and condition. Refer to See: Fluid - CVT > Procedures > Inspection.
May 28, 2019 at 4:18 AM
