Transmission, no gears will engage
203,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
JOHNNY WALKER
Starts, can push in neutral.. Linkage seems fine.. Fluid level right.. Changed filter.
Apr 1, 2020 at 4:25 AM
Good afternoon,
Did you try to change to 4 wheel drive and see if it will move? It could be the transfer case that is causing this.
If it does not engage, then you have an internal failure inside the transmission. It could be the torque converter or the front pump. Either way, it has to come out to be inspected for the failure.
Apr 1, 2020 at 5:35 AM
JOHNNY WALKER
Thanks Roy. I did try 4wd and still nothing. Is it possible the neutral safety switch could cause this? Provides feedback to computer regarding gear select I think.
Apr 1, 2020 at 5:52 AM
JOHNNY WALKER
I know I'm fishing, but a bad day fishing is better than a good day of transmission removal.
Apr 1, 2020 at 5:55 AM
No, this is a mechanical issue not and electronic issue. There are no sensors for mechanical application.
Sorry, you need a transmission.
Apr 1, 2020 at 6:07 AM
JOHNNY WALKER
Appreciate your help Roy.. off to Pick n' Pull I guess.
Apr 1, 2020 at 6:11 AM
You are welcome.
Always glad to help.
Apr 1, 2020 at 6:15 AM
