Transmission
DOM28
  • 2007 VOLKSWAGEN BEETLE
I recently changed the transmission pan but now I can not find where to fill it with transmission fluid. Where is this located?
Saturday, April 13th, 2013 AT 6:01 AM
  • 52,797 POSTS
� Remove ATF inspection plug from oil pan.
The ATF present in the overflow tube runs out.
If ATF drips out of drilling:
ATF does not need topping off.
� Install new seal to plug and tighten to 15 Nm. This completes the ATF check.
If no ATF drips out of inspection hole:
� Top off ATF => [ ATF, Filling ] See: Service and Repair 09G Transmission
Saturday, April 13th, 2013 AT 6:33 AM
