Transmission has no forward gears
212,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
DAN ABEL
I have reverse but no forward gears.
May 9, 2019 at 3:47 PM
Good morning,
It does sound like you have an internal failure in the transmission. The forward clutches may have failed not allowing forward movement.
You could try changing the fluid and filter in the transmission to see if the filter is clogged.
May 9, 2019 at 7:38 PM
