Transmission shifting hard
93,999 MILES • AUTOMATIC
JESSICA ROSEMANN
Transmission hesitates to go into second and third kicks hard when it does. Also, TOD light on and i cannot find dip stick to put fluid in. how do i fix these problems? i have extremely low income.
Aug 10, 2017 at 5:56 AM
  • 55,748 POSTS
If the engine has low vacuum to will cause the transmission to shift late and hard. The main cause for this condition is a plugged catalytic converter. The TOD light will be on as well becasue the computer sees that it is not going into overdrive.
Here is a guide that will help you confirm the problem.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please let us know what you find.
Cheers, Ken
Aug 16, 2017 at 4:30 AM
