transitions Honda accord 1986
103,834 MILES • 2.0L • 4 CYL • AUTOMATIC
ADNAN1962
  • 12 POSTS
Delays in the transitions from the first to the second and then the third, but back to normal when you walk the distance is not nearly as long as 1k
Is the problem in the automatic transmission?
Apr 22, 2016 at 5:22 PM
  • 31,937 POSTS
Sounds as if the line pressure is low, this can be checked by a transmission specialist and also a code read will be a good place to start, let me know what you find.
Apr 22, 2016 at 10:19 PM
AL514
  • 5,702 POSTS
Definitely sounds like a low pressure problem, could it be the transmission pump on the way out. But yeah mhpautos is right. go with a transmission specialist.
Apr 23, 2016 at 1:53 AM
  • 31,937 POSTS
get the pressures checked and report back the findings.
Apr 23, 2016 at 10:16 AM
ADNAN1962
  • 12 POSTS
I noticed a decrease in speed automatic transmission oil.
Apr 24, 2016 at 5:10 PM
ADNAN1962
  • 12 POSTS
  • 31,937 POSTS
Make sure that the oil level is correct and the oil is not burnt and dark looking.
Apr 24, 2016 at 6:36 PM
ADNAN1962
  • 12 POSTS
Although I have put the oil on the correct level, the problem is still there?
Apr 25, 2016 at 2:35 AM
  • 31,937 POSTS
get the transmission inspected by a professional first hand, the problem will be internal.
Apr 25, 2016 at 7:28 AM
