Transmission
210,000 MILES • MANUAL
SIBUSISOCELE
The gears get stuck. There is noise when i release the clutch.
Jun 28, 2017 at 1:25 AM
STEVE W.
  • 15,410 POSTS
Sounds like the transmission has internal damage or the shift forks are bent. The noise from the clutch could be input shaft bearings.
Either way the only way to tell is to open the transmission and check for damaged parts.
Jun 28, 2017 at 1:44 AM
