What is the cost to replace the Transfer case?
96,000 MILES • 4WD • AUTOMATIC
KASEYMCLAURIN40
How many hours and what rate of pay should be used to take a transfer case out and put another one in?
Jun 21, 2023 at 7:39 AM
  • 110,248 POSTS
I'm not sure which engine you have, so I went with a 5.0L. If you look below, I attached and highlighted the time allotted for removing and installing the transfer case.
As far as the hourly rate is concerned, that is determined by the shop. I have no idea where you are located, so it could be different than where I am.
Let me know if this helps or if you have questions.
See pic below.
Jun 22, 2023 at 1:36 PM
