If the fuse is good, I have seen the transfer case motor go out on these trucks, here is the location of the motor and the transfer case wiring diagram as requested. Check out the images (below). Please let us know what happens.
Images (Click to enlarge)
Jan 21, 2025 at 4:28 AM
BRIAN W PERREAULT
MEMBER
Thanks. I’m a retired driveline mechanic and have worked on many 246s but if you don’t know how they work you can’t fix them. I was having too much trouble finding a wiring diagram for my personal Durango. Thanks again. I’ll let you know what I find out.
Jan 21, 2025 at 6:05 AM
✓Experienced Mechanic
You are welcome, please let me know if you need anything else.
Jan 22, 2025 at 12:48 AM
BRIAN W PERREAULT
MEMBER
Got it ! Loose terminal connection inside the TCCM. I send to you a virtual beverage of your choice. Thanks.
Jan 25, 2025 at 12:21 AM
lol nice! Glad you found the problem, please use 2Carpros anytime :)
