Transfer case swapping
2004 JEEP GRAND CHEROKEE
200,000 MILES • 4.0L • 6 CYL • AWD • AUTOMATIC
HELP1
Will a nv 247-J transfer case from a 4.0 work in a 4.7 with a nv 247-J transfer? I have a 04 wj with bad transfer its a 4.0 and only used transfers I have found are for 4.7 but has to be a 247-J transfer case. Any help on this. Thanks
Apr 1, 2017 at 6:24 PM
HMAC300
  • 48,601 POSTS
we list two a 242 and a 247 but as long as tag says gear ratio is same I do not see why not. just make sure shaft size is okay to hook up to transmission as that may be different because of a V8, but you can measure that quickly enough.
Apr 2, 2017 at 4:59 AM
