Transfer case stuck in neutral
2001 GMC SIERRA
225,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MICHAEL FRANTZ
My truck listed above SLT 1500 is not moving at all. The encoder motor is off the transfer case. i attempted to manually set transfer case in neutral but i didn't have the transmission in neutral at the time. So now the transfer case range select/encoder motor shaft is pointing down like it is in neutral but when i go through the
shift P R N D 3 2 1 it grinds very lightly going back into park. No movement in any gear at all. How do i get it into 2hi?
Feb 24, 2019 at 9:43 AM
