Transfer case lock in and front axles locked in
70,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
DOUG N
Jeep is in 2 wheel drive transfer case and axles are locked in why is this happening
Feb 21, 2016 at 12:21 AM
  • 55,797 POSTS
You have an transfer case actuator that is probably bad. I would remove the unit and check it for broken pieces it will be obvious.
Mar 7, 2016 at 7:23 AM
