Transfer case fluid change?
187,000 MILES • 6 CYL • 4WD • AUTOMATIC
ASHLIE_LINCOLN
What size washer to replace with? The Amazon link leads to a set with all sizes.
Mar 6, 2026 at 7:14 AM
  • 55,710 POSTS
Hello, yes that is for the kit, here is the size for the washer as requested.
Toyota Part Number: 90430-18008
Dimensions
Inner Diameter: -18 mm
Outer Diameter: - 24 mm
Material: Aluminum crush washer
Here is the video to help you change out he fluid as well.
https://www.youtube.com/watch?v=w2HFLkJ_QtM
Use 2CarPros anytime, we are here to help. Please tell a friend. Ken
Mar 7, 2026 at 4:30 AM
