Transfer case control module
284,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JENS79SHOVEL
I picked up a transfer case control module from a junkyard. The guy told me i have to have it reprogrammed. Is this true?
Dec 6, 2019 at 7:59 AM
94 TRANSAM
  • 680 POSTS
A new module will have to be programmed. A used one that has been programmed my or may not depending on application match.
Suggest you put it in and try it. If it doesn't work its either bad or needs programming.
Rich
Dec 6, 2019 at 10:52 AM
STEVE W.
  • 15,394 POSTS
As Rich says, try it. If it came out of a truck with the same transfer case and engine it may work as is. However it may also not have the latest software in it as there have been a few updates.
Dec 6, 2019 at 11:20 AM
JENS79SHOVEL
Will any harm come to my vehicle if it doesn't work?
Dec 6, 2019 at 11:38 PM
94 TRANSAM
  • 680 POSTS
No, it just wont work.
Rich
Dec 7, 2019 at 10:11 AM
