Transfer case control module
16,789,765 MILES • 5.7L • V8 • 4WD • AUTOMATIC
LARRY WILLS1
I am trying to locate the transfer case control module on my pickup . It is not on the passenger side kick panel or on the drivers side under the dash. Any ideas?
Mar 12, 2016 at 1:18 AM
HMAC300
  • 48,601 POSTS
it is under the dash on the steering column support bracket.
Mar 12, 2016 at 2:24 AM
LARRY WILLS1
I found it, thank you.
Mar 13, 2016 at 6:52 PM
LARRY WILLS1
I have replaced the actuator, the decoder motor and transfer control module. When I put the fuse in, it is making a clicking sound with the key off and engaging the 4 low, and the lights on the 4x4 switch are blinking. I have the electronic 4x4. I had to replace the transmission, before it was replaced everything worked, any ideas?
Mar 20, 2016 at 3:05 PM
HMAC300
  • 48,601 POSTS
Check your connections all around and scan for codes. It may be a short in wiring, also put your old tcm back in and see if it still clicks etc. If you ever have a problem with this vehicle you should always scan for codes first.
Check out this link for more information.
https://www.2carpros.com/topics/general/tools/scanner?page=2
Mar 20, 2016 at 3:55 PM
