Transfer case
250,000 MILES • 6 CYL • 4WD • AUTOMATIC
CARTROUBLE101
I took my vehicle in to change the oil they told me that the transfer case fill plug was stripped. why did they took it out in the first place? i do not know. anyway they put in a rubber one, will it be okay or will it pop out of place?
Nov 28, 2017 at 10:16 AM
  • 31,937 POSTS
As long as it is a firm fit it should be okay. the transfer will have a breather so no internal pressure will build up to pop out the plug. you should be able to re thread the filler plug hole and fit a new plug, pending on access you should be able to do this in place.
Nov 28, 2017 at 12:42 PM
