Transfer case
1982 AMC EAGLE
14,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVID TOWSLEY
Transfer case slips out of two wheel drive into a neutral position and will not go back in unless put in manually at transfer case and will still pop back out. The vacuum mechanism was taken out by a transmission mechanic to keep it in gear, but I need to know how to fix the issue or at least find out what is wrong?
Jan 6, 2017 at 7:14 AM
HMAC300
  • 48,601 POSTS
take the case out and fix either the bent fork or clutch gear that may be worn out or bearings worn out.
Jan 6, 2017 at 7:32 AM
