transfer case
244,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
DODGENWW
  • 56 POSTS
I put it in 4L and 4H and wen I went to put it back in 2 wheel drive the shifter just moves freely not locking back in to 2 wheel drive
Mar 9, 2016 at 11:20 AM
HMAC300
  • 48,601 POSTS
check to see if the encoder motor on tcase works it may not or only go one way. scan for codes as well
Mar 9, 2016 at 9:39 PM
DODGENWW
  • 56 POSTS
Ok I got this fixed now wen u shift on the column say u shift from park to reverse well it doesn't light up the Road or if ur in drive it says ur in neutral wat is this
Mar 11, 2016 at 12:47 AM
DODGENWW
  • 56 POSTS
That's the R not road
Mar 11, 2016 at 12:48 AM
HMAC300
  • 48,601 POSTS
scan for codes it may be the trans switch is going bad that tells what gear you arein
Mar 11, 2016 at 1:31 AM
