transaxle range switch accent 2005 - backup light
2005 HYUNDAI ACCENT
1.6L • 4 CYL • FWD • AUTOMATIC
ENGST
I have Hyundai accent 2005 Automatic transmissions and I had problem with backup light not working
To try to solve the problem you I was removed transaxle switch and cleaned inside it
after reinstalled it again I noticed backup light working all time with R,N,D,1.2 except P not only with R
what can I do pls help
Feb 4, 2014 at 6:28 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
id have to say it sounds like that switch is done. it sounds like its shorted internally. replace it
Feb 4, 2014 at 6:42 AM
ENGST
ty 4 ur answer but I hope to find a solution without change switch
Feb 4, 2014 at 7:03 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
you could always try to take the switch apart and fix it since youre ambitious. sometimes they can be fixed
Feb 4, 2014 at 7:27 AM
ENGST
thank you again
I Replaced it today
Feb 5, 2014 at 5:05 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
glad I could help. is it working?
Feb 6, 2014 at 8:33 AM
