Transmission wiring
999 MILES • 5.7L • V8 • 4WD • AUTOMATIC
T&TSALVAGE
Put drive train in a 1999 Jeep Wrangler. No four wheel drive indicator, no neutral safety. Could you send me a wiring diagram and tell me how to make speedometer work?
Jan 2, 2018 at 1:57 AM
CARADIODOC
  • 34,414 POSTS
The speedometer is driven by a digital signal from the original transmission computer. You have Chevroletparts in a Chrysler body. You would need to figure out how to mount an input speed sensor and the correct output speed sensor, then how to create notches on the tone ring on the turbine shaft and on the rear drum. It would be far easier to put the original transmission back in.
Jan 2, 2018 at 6:38 AM
