Transmission stuck in first
116 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
GREGORYL
It goes into reverse fine, it just will not shift out of first even in drive third or second it is in first.
Jul 24, 2017 at 12:29 AM
HMAC300
  • 48,601 POSTS
try putting in low then shift to second see if it does it. it may be a valve body/governor problem which a transmission specialist should check. See link.
Jul 24, 2017 at 1:34 AM
