transmission shift solenoid replacement
200 MILES • 3.0L • V6 • 4WD • AUTOMATIC
BYRONSESSOMS
can they be replaced without removing the transmission?
Jun 22, 2019 at 12:12 AM
Hi Byron,
I assume you are talking about the shift solenoids that are in the valvebody? If so, I included the procedure on how to remove the valvebody and reinstall it and yes, you can do it without removing the transmission.
Please let me know if you have any other questions on this issue. Thanks
Jun 22, 2019 at 3:14 AM
SANCHEZ CRYSTAL
Do you happen to have a diagram of the transmission shift solenoids? I bought 1 I just don’t know if it’s shift A or B.
Jun 3, 2022 at 5:21 AM
SANCHEZ CRYSTAL
To a 2016 Ford Escape se.
Jun 3, 2022 at 11:55 AM
We can definitely help with that but let's get a new post started so that you can provide all your specifics. We need to know what engine you have as there are 3 options and that will potentially affect the transmission diagrams.
Also, while this is related to this topic, this is a good question, and I would like others to find the answer and they most likely will not find it under this topic.
Sorry for any inconvenience. Thanks
Jun 3, 2022 at 11:58 AM
