The car listed above is a Coupe. The car will take off and shift up through all the gears however if you come to a stop or slow down it will only shift first and second gears and no higher. I can pull over shut the car off fire it right back up and it will once again shift all five but first stop or slow down its back to second gear and no higher. Code told me low pressure and I replaced the external shift solenoids, but it didn't help, still does it. Any and all help would be greatly appreciated.
May 12, 2023 at 8:15 AM
