My ABS light comes on when in drive sometimes. It idles a little high shifts poorly in first and maybe second.
Apr 10, 2017 at 1:52 AM
EDDIE GRIZZLY
MEMBER
Also, speedometer inaccurate at times and the right blinker is slightly lit while in park or reverse but not all the time.
Apr 10, 2017 at 2:19 AM
HMAC300
✓Experienced Mechanic
check ground for left taillight as that may be cause of slightly dim. have a mechanic scan for codes for the ABS problem. He may pick up a code for transmission problem as well unless it is an accumulator problem which a transmission professional should look into for that.
