Transmission problem, codes po743 and po753
201,867 MILES • 5.9L • V8 • 2WD • AUTOMATIC
1OLIVETTI690
My vehicle ran out of gas sat two days put gas in and started it went to drive, now will not shift out of first gear. Checked codes found two po743 and po753. Replaced valve body and still have same code and still will not shift. Help
Jul 29, 2018 at 12:42 PM
Good morning.
Below are the descriptions and possible causes for the failures. In most cases, it is a wiring issue.
SYMPTOM
P0743-TORQUE CONVERTER CLUTCH SOLENOID/TRANS RELAY CIRCUITS
WHEN MONITORED
Continuously with the key on.
SET CONDITION
This code will set if the voltage detected on the Torque Converter Clutch Solenoid Control circuit at the PCM is different than the expected voltage.
POSSIBLE CAUSES
- TCC solenoid control circuit open
- Fused B+ circuit open
- TCC solenoid control circuit short to ground
- Transmission relay output circuit short to ground
- TCC solenoid control circuit short to voltage
- TCC solenoid control circuit short to other circuits
- Transmission control relay output circuit open
- Torque converter clutch solenoid
- Transmission control relay - poor contacts
- Powertrain control module
- Intermittent wiring and connectors
753
SYMPTOM
P0753-TRANS 3-4 SHIFT SOL/TRANS RELAY CIRCUITS
WHEN MONITORED
SET CONDITION
This code will set if the voltage detected on the 3-4 Shift Solenoid Control circuit at the PCM is different than the expected voltage.
POSSIBLE CAUSES
- P1765 DTC present
- 3-4 shift solenoid control circuit open
- 3-4 shift solenoid control circuit short to ground
- 3-4 shift solenoid control circuit short to voltage
- 3-4 shift solenoid control circuit short to other circuits
Jul 29, 2018 at 8:26 PM
1OLIVETTI690
Already replaced valve body. Do you think the PCM might have gone bad? I replaced valve body do to this problem.
Jul 29, 2018 at 11:22 PM
That is the last thing I would suspect as well as the valve body.
You need to verify wiring to the transmission. It could be a short in a feed wire or the return to the PCM. all this needs to be checked before throwing a expensive PCM at this that will not resolve the issue.
Make sure there is not transmission fluid in the connector that goes to the transmission.
Jul 29, 2018 at 11:40 PM
1OLIVETTI690
Well, checked all that found a blow fuse for transmission and still 02 sensor. Replaced both no check engine light still no shift.
Jul 31, 2018 at 2:09 AM
Did you pin out the harness and verify voltages to each solenoid?
Jul 31, 2018 at 3:38 AM
1OLIVETTI690
Not yet, will do that let you know.
Jul 31, 2018 at 9:27 AM
Okay, thank you.
Jul 31, 2018 at 9:39 AM
