Transmission will not shift into overdrive or fourth gear
1993 CHEVROLET BLAZER
168,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
93S10BLAZER4X4
Had to replace radiator, while the transmission and oil lines were disconnected the motor was started and put into gear for less than 5 seconds. Now the transmission won't shift into fourth gear/overdrive.
Feb 25, 2022 at 4:06 AM
  • 110,240 POSTS
Did the fluid totally drain? Is there anything other than 4th/OD that is being affected? Does it shift properly in the other gears?
Now that things are back together, is the ATF clean and full? Is there any evidence of air in the fluid or contamination from coolant?
Let me know. Also, try to retrieve diagnostic trouble codes to see if there is anything that may help us. You don't need a scanner. All that is needed is a short jumper wire or even a paper clip. Here is a link that explains how it's done:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know as much as you can. Also, if you find there are codes stored, let me know what they are.
Feb 25, 2022 at 12:25 PM
93S10BLAZER4X4
There was something else, and it has never done this before. Oe the coldest days this winter the transmission hesitated in reverse. But only when the engine temperature was below normal, after it warmed up it worked fine. Yes, transmission filter and fluid was drained and changed. Still no 4/over drive and no codes.
Feb 26, 2022 at 3:47 AM
  • 110,240 POSTS
Thanks for the update. A delay in reverse (which requires the highest line pressure) can simply be the result of the fluid condition in extreme conditions. By chance, were you able to check for codes?
I'm starting to question the shift linkage. On 4-Speed automatics, it is possible to drive the vehicle in 3rd gear rather than "overdrive" and not perceive it. Typically, this condition occurs when the shift indicator or the shift linkage/detent is misadjusted. Misadjusted shift linkage can also result in improper signals to the ECM, which can result in less spark advance, and results in a drop in fuel economy.
I'm questioning this because what happened that seems to have led to the issue shouldn't have caused this to happen. Running for less than 5 seconds wouldn't have emptied the fluid.
Do me a favor. Let's see if the shift linkage is out of adjustment. When you were working on the vehicle, anything could have happened.
If you look at the pics below, they explain how to adjust the linkage on this vehicle. Take a look through them and let me know if you are comfortable performing them. Additionally, I am making the assumption that this is an S-10 Blazer and not a full size. If that is incorrect, please let me know.
I will watch for your reply.
Feb 26, 2022 at 11:13 AM
93S10BLAZER4X4
The shift linkage/indicator has always been one off. Example or matter of fact. Park always above the park indicator, then down shifting reverse, neutral, drive.
Feb 26, 2022 at 5:24 PM
  • 110,240 POSTS
Try adjusting things. If that has been the case, there is a chance it is finally far enough off that it is causing the issue. Although you see it off in the vehicle, it could be off at the transmission and causing this.
I know I read a technical service bulletin (TSB) similar to this in the past. For the life of me, I can't remember it 100%. I will keep looking for it and let you know if I find it.
It may seem like a long shot, but again, I don't think what happened hurt the transmission.
Feb 27, 2022 at 11:14 AM
