truck will not shift into gear unless it is pretty warmed up
110,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
TOM LOMBARDI
My truck will not shift into gear unless it is pretty warmed up, and even then it has a hard time. I have replaced the transmission fluid, and the clutch has plenty of pressure, which I hope rules out the slave cylinder.
Nov 12, 2017 at 12:25 PM
  • 55,711 POSTS
This sounds like you have a clutch disc that is falling apart or the pilot bearing is seizing up.
Here is a couple of guides showing you what you are in for when fixing the car:
https://www.2carpros.com/articles/how-to-replace-a-clutch
and
https://www.2carpros.com/articles/pilot-bearing-replacement
and
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Cheers, Ken
May 3, 2021 at 7:21 AM
