Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Sierra
Drivetrain
Transmission
Symptoms
Not Shifting
Transmission not shifting from second to third gears
1990 GMC SIERRA
162,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
FEEZO34
MEMBER
1 POST
Shifts from first to second then when it should go third gear it just spins RPMs.
Oct 18, 2021 at 5:06 PM
Experienced Mechanic
Good morning,
This sounds like the third clutches or direct clutches are worn out and cannot apply to move the truck.
You will most likely need either an overhaul or a replacement of the transmission.
https://www.2carpros.com/articles/how-to-remove-an-automatic-transmission-rwd
Oct 18, 2021 at 7:38 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
