Transmission not shifting from second to third gears
162,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
FEEZO34
Shifts from first to second then when it should go third gear it just spins RPMs.
Oct 18, 2021 at 5:06 PM
Good morning,
This sounds like the third clutches or direct clutches are worn out and cannot apply to move the truck.
You will most likely need either an overhaul or a replacement of the transmission.
https://www.2carpros.com/articles/how-to-remove-an-automatic-transmission-rwd
Oct 18, 2021 at 7:38 PM
