trans/Gear
21,334,510 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
BAUMBER1
The flashing N light and within minutes the car lost all drive trans fluid was good and showed no signs of any faults now still no drive only rmp unsure of whats wrong please help
Jan 9, 2016 at 9:50 AM
  • 31,937 POSTS
You will need to get the transmission scanned for a fault code, the flashing light is a indication of a code being set in the memory.
Jan 9, 2016 at 5:37 PM
BAUMBER1
Thank you very much i had a play around anf found water in my tranmission plug leading to the gearbox may need a new lead heres hoping shes a sweet runner just need the power back quick question where do i take her for a diagnosis!? i only have a engin diagnotic
Jan 10, 2016 at 1:49 AM
  • 31,937 POSTS
A good quality scanner will have the transmission as a sub section to read, best would be a large private work shop or a dealer.
Jan 11, 2016 at 4:50 PM
