Transmission fluid leak
210,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
KEVIN ROSENBUM
Changed CV axle, seal, hub bearing, motor mount, and still have transmission fluid leak.
Feb 9, 2018 at 1:13 AM
Where does the leak appear to be coming from?
Feb 9, 2018 at 1:58 AM
KEVIN ROSENBUM
CV axle into transmission passenger side.
Feb 10, 2018 at 10:55 AM
Okay, thanks.
There is a seal at the transmission for the axle. it is called a bulk head seal. you need to remove the axle again and use either a seal puller or a large screw driver with an angled end. then be careful installing the new one as not to damage it. then install the axle.
Feb 10, 2018 at 4:31 PM
KEVIN ROSENBUM
So there is more than one seal you are telling me? thanks.
Feb 10, 2018 at 9:59 PM
No, only one seal for that axle. there is another seal for the axle on the other side as well.
Feb 11, 2018 at 6:13 AM
KEVIN ROSENBUM
Already changed seals.
Feb 11, 2018 at 11:24 AM
If they are still leaking, then there is another issue inside the transmission is a bushing that supports the axle shaft, if it is worn, there will be play in the shaft and that will cause the seal to leak.
Feb 11, 2018 at 9:34 PM
