Transmission fluid in radiator
150,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
GALEN SHAW
Transmission fluid mixing in radiator.
Aug 7, 2017 at 10:43 AM
CJ MEDEVAC
  • 11,000 POSTS
The transmission fluid cooling lines (which enter the radiator on the driver's side of the radiator/high and low) probably has a hole in it somewhere inside the radiator.
Anymore, the 'fix', would be replacing the radiator.
I think this would be your radiator. See link below:
https://shop.advanceautoparts.com/p/carquest-radiator-431406/19920070-P?searchTerm=radiators#
Depending on your location and available parts stores.
This or the same sort of method at another parts store may save you a chunk of change. See how I do well in this link. Keep in mind, promos do change over time and you might have to do a little homework!
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
Let us know how it goes.
The Medic
Aug 7, 2017 at 11:44 AM
