Good afternoon,
I attached the amount of fluid required for changing the fluid. I would drop the pan and change the filter. Then add the correct amount and when you check it with the dipstick, put a mark on the stick for the full mark so you have a reference for the full mark.
Fluid Types
Automatic Transmission Fluid Type
Mopar(R) ATF +4 Automatic Transmission Fluid or equivalent.
Capacities
Transmission Fluid Capacity
Service Fill - NAG1 .................... 5.0Liters (10.6 pts.)
Overhaul Fill - NAG1 .................... 7.7Liters (16.3 pts.) *
Service Fill - 42RLE .................... 3.8Liters (4.0 qts.)
Overhaul Fill - 42RLE .................... 8.3Liters (17.6 pts.) *
Oct 2, 2020 at 3:11 AM
