Transmission filter location
162,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SPARROW34
I just want to know where the location of my transmission filter is and am I going to be able to change it while I'm doing my fluid change? can this be serviceable or in the middle of the transmission?
Feb 11, 2019 at 10:38 PM
SCGRANTURISMO
  • 4,897 POSTS
I have included all the information necessary to do a transmission fluid and filter change on your vehicle down below in the diagrams. Here, also, is a link that you should check out as well:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Thanks,
Alex
2CarPros
Feb 13, 2019 at 11:49 PM
SPARROW34
You showed me nothing?
Nov 23, 2019 at 5:18 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
When you remove the transmission pan you can see the filter where it mounts to the valve body of the transmission.It's held on with 3 bolts.You can remove by hand after removing the bolts.It is best to change the filter when doing a service to replace the transmission fluid. I've attached two pictures below showing its location.Hope this helps and thanks again for using 2CarPros.
Danny-
Nov 23, 2019 at 9:25 AM
